Topic: Bitrate writing away to file
It seems that VDJ writes away a recording mixing session to file in 192 Kpbs standard. Is there any way how one could change that to for example 128 Kpbs or 320 Kbps?
Thanks,
Johan
geposted Tue 24 Oct 06 @ 1:44 pm
DJ-ALFPRO InfinityModeratorMember since 2005
You can select that in options.
geposted Tue 24 Oct 06 @ 2:05 pm
I think Alf means "config" in the record module.
geposted Tue 24 Oct 06 @ 9:39 pm
I also think so, there is a selection list to select between 40kb/s to 320 kb/s.
I just used it for the first time yesterday to create a little compilation that we will use for an opening of a new building Friday
Ewout
geposted Tue 24 Oct 06 @ 11:55 pm
