hi i recently purchased the VDJ Pro and U46dj and i have 2 CDJ 800 and DJM 800 , what else do i need to get so i can do the video mixing on a projector
please let me know
thanks
please let me know
thanks
geposted Thu 26 Oct 06 @ 9:00 am
you need to help out the helpers......what are your system specs?? what is your video adapter? be specific about what you expect your setup for video to be and be very specific....
geposted Thu 26 Oct 06 @ 4:25 pm
I have the Sony Vaio VGN-FJ370
Processor
• Intel® Pentium® M Processor 750 (1.86GHz1 , 2MB L2 Cache)
• Operating System
• Microsoft® Windows® XP Home Edition with SP2
• Front Side Bus Speed
• 533MHz
• Chipset
• Intel® 915GM
• Integrated Wireless LAN
• Intel® PRO/Wireless 2200BG Network Connection (802.11b/g)3
• LCD
• 14.1” WXGA display8 (1280x800) with XBRITE™ technology
• Hard Drive
• 100GB 5400rpm Serial ATA
• Memory
• 1GB PC2-4200 533MHz DDR2 (512MBx2)
• (Expandable up to 2GB)
• Graphics
• Intel® Graphics Media Accelerator 900 128MB Dynamically Shared RAM Video Memory
• Graphics Interface
• VGA out w/ Smart Display Sensor
• Optical Drive
• DVD+R Double Layer / DVD±RW Drive4
• DVD+R DL Write (4x MAX); DVD-R DL Write (4x MAX);
• DVD-R Write (8x MAX); DVD-RW Write (6x MAX)
• DVD+R Write (8x MAX); DVD+RW Write (8x MAX)
• CD-R Write (24x MAX); CD-RW Write (24x MAX)
• DVD-ROM Read (8x MAX); CD-ROM Read (24x MAX)
• Communication
• Integrated MOTION-EYE™ Camera with built-in microphone
• Modem
• Integrated V.92/V.90 Modem (RJ-11)
• Ethernet
• 10Base-T/100Base-TX Fast Ethernet (RJ-45)
• Audio
• Windows® sound system compatible with Built-in stereo speakers
• Audio Interface
• Microphone jack, Headphone jack
• Optional Port Replicator
• 3 USB 2.0 ports, Monitor (VGA) port, Printer port, DVI-D, DC in, RJ-45 Ethernet
• Memory Stick® Media Slot
• Supports optional Memory Stick®, Memory Stick PRO™ and Memory Stick DUO™ media5 with MagicGate™ functionality
• PC Card Slots
• One PCMCIA - Type II/Type I card slot with CardBus support
• Other Interfaces
• 4pin i.LINK®6 connector(IEEE 13943)
• 3 USB 2.0 ports
• Port replicator connector
• VGA out
• AV out
• Pointing Device
• Electro-Static touch pad
• Keyboard
• QWERTY, 88 keys with 2mm stroke and 19.05mm pitch
• Action Buttons
• S1, S2 and Wireless LAN on/off
• Power Requirements
• 105 watts max
• Battery
• Lithium-ion Battery (VGPBPS2A)
• Estimated Battery Life
• 1.5-3.5 hours7 (Standard Battery)
• Weight
• 5.3 lbs. with standard battery (weight is approximate and may vary)
• Dimensions
• 13.4”(W) x 0.83”-1.3”(H) x 10”(D)
• Supplied Accessories
• Standard Lithium-ion battery (VGPBPS2A)
• AC adapter (VGPAC19V10)
Processor
• Operating System
• 533MHz
• Chipset
• Intel® 915GM
• LCD
• Hard Drive
• Memory
• Graphics
• Optical Drive
• Communication
• Modem
• Ethernet
• Audio
• Audio Interface
• PC Card Slots
• Other Interfaces
• 3 USB 2.0 ports
• VGA out
• AV out
• Pointing Device
• Keyboard
• Action Buttons
• 105 watts max
• Battery
• Weight
• Dimensions
geposted Thu 26 Oct 06 @ 6:46 pm
help please
geposted Fri 27 Oct 06 @ 12:57 am
That Laptop's Video Card won't support Hardware Accel, also its shared memory, so unfort. it's won't give you what you need for seemless video mixing
geposted Fri 27 Oct 06 @ 1:31 am
thanks
thanks
just try to connect the vga or dvi or s-video out, to a monitor or tv.
Enable the output from your PC.
Then set it up in VDJ video tab, choose that output.
It will prob work for non accelerated video, but maybe not full power accelerated video with "3D" transition effects. You have lots of super fast ram that your internal gfx card share with system, so maybe you're lucky.. Give it a test;)
If you can't get all the effects and smooth video mix to work good, its because the grahpic card is not a dedicated one, with its own ram. You should use a laptop with an ATI or Nvidia card for that...
geposted Fri 27 Oct 06 @ 1:37 am
please help tell me what do i need to control the video fader since i have the DJM 800 can i do it wit my mixer . and also can i add EXTERNAL Video Card
please help
please help
geposted Fri 27 Oct 06 @ 3:21 am
please help
please help
External Video cards for laptops are only good for Karaoke and Bitmaps, not for videos
If the mixer isnt MIDI than you cant control the fader with it, but you can configure your sound card to put out side a and b seperate to the mixer
geposted Fri 27 Oct 06 @ 5:04 am
is this laptop good. i have the DJM 800 can i use the fader to also do the video and if i can what do i need.
http://www.costco.com/Browse/Product.aspx?Prodid=11170779&whse=BC&Ne=4000000&N=4017747&Mo=12&pos=1&No=5&Nr=P_CatalogName:BC&cat=4338&Ns=P_Price|1||P_SignDesc1&Sp=C&ec=&topnav=
geposted Fri 27 Oct 06 @ 7:05 am
I have the same problem .....my laptop w/ 2 gigs of ram has a crummy default video adapter w/ 128 mb shared ram (Ati radeon express 200). I can't get it to do anything beyond extend the desktop.
As far as I know there is no work around; can't use an external vid adapter w/ a laptop.
So......looks like the desktop backup system is in for a major upgrade......
geposted Fri 27 Oct 06 @ 2:19 pm
can i use my DJM 800 to control the fader if i can how ?
geposted Tue 31 Oct 06 @ 9:20 pm
Yes you can, you need to enter to midi setup and to configure it manually by moving the fader in order that vdj detects the midi knob and linking the audio and video crossfaders.
geposted Wed 01 Nov 06 @ 3:53 am
can u please post how you can all do that. maybe steps throuhg the set u p
thanks
thanks
geposted Wed 01 Nov 06 @ 8:26 pm
- Go to remote control
- Enable midi and press config
- Then press add and move the djm 800 crossfader
- From the list select video then video_crossfade and press ok
- Enable linked crossfaders in video menu
hope it helps :)
geposted Wed 01 Nov 06 @ 11:03 pm
Is there an expensive midi controller to buy? Any suggestions too?
geposted Wed 01 Nov 06 @ 11:27 pm
do i need a midi cable to USB
Use the XPS 1710 instead, the 1210 videocard won't support VDJ hardware acceleration
geposted Thu 02 Nov 06 @ 1:33 am
almost all Creative soundcards have a midi port on them, they are generaly cheap.
geposted Thu 02 Nov 06 @ 1:35 am
so what laptops do you guys recomend to buy so i can do the video mixing im tryiing to get my final answer , cause no body tells me what i need to get this video mixing working. please help me and tell me what laptop is good to buy
geposted Thu 02 Nov 06 @ 1:53 am
any help
geposted Mon 06 Nov 06 @ 11:31 pm
