my collage has now blocked virtual dj forums
again!
previously i had a work around for this however they solved that
i found a new work around in which if you type the ipadress of the website it allows you to go to that page
so i hopefully pinged virtual dj .com hoping to get to the forums
but the ip takes me to www.atomixproductions.com
does any one have any ideas on how to get to the forums as they keep me sane in free periods
thanks :D
again!
thanks :D
geposted Fri 27 Oct 06 @ 3:22 pm
Have you tryed all the proxy sites you can find?
At my school, they blocked everyone I went to, but i found one that they didnt end up blocking.
Its called www.ninjaproxy.com
Hope this helps
Phatt B
Hope this helps
Phatt B
geposted Fri 27 Oct 06 @ 3:25 pm
thanks!!, cant test it now lol
but will do when i go back
unfortunatley they aslo have a rule for webased proxys so not sure if it will work
and if you go to lan settings and create a proxy rule to the ip of the proxy server it blocks all pages
just have to hope for the best lol
might have to march down to ict department and threaten terrible things if they dont unblock it lol
geposted Fri 27 Oct 06 @ 3:31 pm
Ah righto.
Well becuase I'm only in year 10. If you get past the school blocks and go to sites that arnt aloud. All that happens is that you have to pay a visit to the principle, and have your account banned for a week. lol, so i was happy to try the proxies I found.
geposted Fri 27 Oct 06 @ 3:35 pm
Can you logon to the Atomixmp3.com site?
geposted Fri 27 Oct 06 @ 3:42 pm
been told its against all forums but
will try the atomix site ;) tho lol
thanks for that idea its so simple i missed it
failing that i might have to do some ethical hacking ;)
geposted Fri 27 Oct 06 @ 6:21 pm
