Forum: Old versions
Topic: USB lack of power?
apparently my laptop is not 2.0, after I hook up the MK2, my external USB Harddrive turns off because the MK2 sucks up all the power
I plan to buy the maya44, is there a device/hub or w/e that can fix this problem?
btw i have only 2 USB outlets, i think its 1.1
geposted Sat 28 Oct 06 @ 1:58 am
phillydjPRO InfinityModeratorMember since 2004
a powered USB hub will do the trick
geposted Sat 28 Oct 06 @ 1:59 am
U can also pcmcia card that has usb 2.0 ... if ur laptop is not 2.0 this the only way to get 2.0 on the laptop that i am aware of
geposted Mon 30 Oct 06 @ 7:39 am
sbangsPRO InfinityMember since 2004
you can get an adaptor for one port for 2.0 devices to conect to a 1.0 port
but a pcmcia card would be better
geposted Mon 30 Oct 06 @ 11:24 am
rEsKPRO InfinityMember since 2006
Are you sure about this? If you use an adaptor the bus speed still working at the same speed than usb 1.0. The only way is a pcmcia usb 2.0 card.
geposted Mon 30 Oct 06 @ 12:49 pm
im sure iv seen it somewhere will have a look
maybe im going mad lol
geposted Mon 30 Oct 06 @ 12:59 pm
geposted Mon 30 Oct 06 @ 1:04 pm
Ok, but it works at the usb host port speed:
If the host port is 1.0 it works ar 1.5mbps
If it's 1.1 then works at 12 mbps
And if it's 2.0, works at 480 mbps
You are limited by the usb bus speed of your motherboard.
geposted Mon 30 Oct 06 @ 1:15 pm
geposted Mon 30 Oct 06 @ 1:44 pm
