Difficult to explain this one, I'm after a cable... 3.55mm jack at one end to plug into my laptop, then split into left/right phono to plug into a mixer... what's the proper title for the this cable!? Trying to find out on HTFR.com or Ebay but struggling without knowning the right term.
Thanks in advance
Edit: title should be "splitter cable"
Thanks in advance
geposted Mon 30 Oct 06 @ 5:25 pm
you want a 3.55 mm( mini jack)
to double phono cable :)
geposted Mon 30 Oct 06 @ 5:30 pm
Thanks, where is the best place to get these? UK if possible!
geposted Mon 30 Oct 06 @ 5:35 pm
maplin electronics sell them
most computer and hifi shops do aslo
geposted Mon 30 Oct 06 @ 6:13 pm
http://www.maplin.co.uk/Search.aspx?criteria=3.5MM%20JACK%20TO%20DOUBLE%20PHONO&menu=0&WorldSearch=Y&doy=31m10&ShowPics=true&Stock=28&MinPrice=0&MaxPrice=9999&SD=true
Tried searching on Maplin, can only find the adaptors though?
geposted Tue 31 Oct 06 @ 11:59 am
Twin Phono to 3.5mm Stereo Jack Lead
there words for it
there words for it
geposted Tue 31 Oct 06 @ 1:04 pm
The sort of cable which enables you to connect a CD Walkman, DAB digital radio or minidisc player to a stereo amplifier? Most electrical shops sell them.
geposted Tue 31 Oct 06 @ 3:26 pm
