Topic: Numark using Automix Software called Cue.
cerriexPRO InfinityMember since 2004
I notice numark have released Cue a new Mixing program.. tho it looks exactly like VDJ V4 with modified skin..
If Numark make any improvements on the software i.e time code opperation.. Do we as VDJ Owners get to bennifit from it?
My time code has never worked for more than an hour without locking up.. so i only use it at home and stick to keybored at the pub.
geposted Tue 31 Oct 06 @ 7:58 pm
Bren FPRO InfinityMember since 2003
Virtual DJ (Atomix) are the authors, owners and modifiers of Virtual DJ, period. Cue is exactly the same program with its own official skin. So if any improvements are made anywhere, they'll be made here as they are, which Cue will also benefit from. Who drives the 'update' agenda is debatable, but the tradition of Virtual DJ has always taken its users views and requirements into strong consideration when prioritizing development for updates.
This is correct as far as I understand it.
geposted Tue 31 Oct 06 @ 8:48 pm
Must be something wrong. I've used timecode for hours and hours and it never gives problems either with Vinyl or CD. I recommend trying again. It's great.
geposted Tue 31 Oct 06 @ 9:05 pm
Or create a post with a description of the problems you have. Most problems will be sorted just by advice from other forum members.
Ewout
geposted Wed 01 Nov 06 @ 2:41 pm
Since the 4.1 upgrade I have had absolutely no problem or glitches related to timecode. VDJ is solid as a rock at the moment.
geposted Wed 01 Nov 06 @ 4:17 pm
