Hi, asked this question a log time ago but not sure if its changed since then as there have been many updates
I would like to run a video (MPG or similar) in the background to run all the time on the screens, I have made up some adverts that I would like to show, when I play a music vid I want to switch over & then straight back after (like the was the Sonique Visualatins work)
Is this possible? I can play it via a MPG as a track but this is far from ideal as I can not cue tracks ups while 1 is playing.
Chris
Chris
geposted Fri 03 Nov 06 @ 6:29 pm
I could use that feature too! I wonder...can we play an ambiant video consistently while mixing mp3's back and forth? For example, let's say I want to play two tracks (which have no video) back to back. is there a way to let a video play continuously while I do this mix? same thing with the live video feed.
geposted Fri 03 Nov 06 @ 7:05 pm
You might try windows media in loop play for that one mpg n the background.
geposted Sat 04 Nov 06 @ 9:26 pm
or you can use visual plugin for all songs which are not videos , you can aslo display your logo on top of the plugins
http://www.virtualdj.com/addons/tools.html
look for backround plugin
geposted Sat 04 Nov 06 @ 9:53 pm
