I need some help to make a "Virutal Dj server"
I want some friends to listen to my music! :D
Where can i get a "server" ? :O
Help me please.. :/
Help me please.. :/
geposted Sat 04 Nov 06 @ 12:25 am
it would help if you bought the software...
geposted Sat 04 Nov 06 @ 12:34 am
Help me please.. :/
Help me please.. :/
VDJ has the streaming server built into the application. However if you want to use a seperate server, try using some of the shoutcast compatible server components. And oh yeah, [skyfxl] is right. Buy the software. You'll be happier.
geposted Sat 04 Nov 06 @ 1:33 am
for an external host try
www.listen2myradio.com as a host
they provide infomation
correct settings to steam from your pc
1 meg broadband - shoutcast 40 kbs
2 meg + shout chast 96 kbs
number of listeners should line up with the amount of ram on your pc
14kb per listener
press ok
and press start
however as mentioned its important you purchase this product to get the best out of it
14kb per listener
press ok
and press start
geposted Sat 04 Nov 06 @ 1:45 am
And I don't think it right to broadcast music without buying the program used to produce the mix first
geposted Sat 04 Nov 06 @ 10:33 am
i concir
but its fair enough for private testing
geposted Sat 04 Nov 06 @ 2:44 pm
