Hello, I have a little problem here, I try everything and seems that I can't figure it out.
Here's my scenario. When One side of the deck is playing and load a song into the
the other deck, the pitch change on the deck that is playing to match the song that I just loaded. The problem with this is the deck that is playing will may slow down or go fast the picth that everybody is hearing it. Is there a way to change the picth only on the deck that you just loaded the song to match the picth of the other deck thats already playing.
My set up is this:
DAC3,
Vmix4 Skin
DAC-3 mapper V1.4 by J.P.Boggis
PLS help
Benmac
My set up is this:
DAC3,
Vmix4 Skin
PLS help
Benmac
geposted Sat 04 Nov 06 @ 5:02 pm
look in the options
and disable always match bpm
and pitch
and pitch
geposted Sat 04 Nov 06 @ 5:31 pm
Thanks Skyfxl, I still like to sync the the 2 decks when i'm mixing, the only complaint i
got it or I don't know how to do it is...... the deck that is playing should not change the pitch.
Only the other deck( That I just loaded a song) should change.
bmac
bmac
geposted Sun 05 Nov 06 @ 3:28 am
press sync
geposted Sun 05 Nov 06 @ 5:00 pm
