Hi all I am trying to get the BCD2000 to work but I keep getting a asio sound drive erro. I did everything juliocqb said to do at
http://www.virtualdj.com/blog/juliocqb/
what can I try
what can I try
geposted Sun 05 Nov 06 @ 10:30 pm
do u have the latest driver can you post a picture of your sound setup here
use www.tinypic.com to get a bb code for your image
geposted Sun 05 Nov 06 @ 10:35 pm
geposted Sun 05 Nov 06 @ 11:00 pm
are you using mac?
geposted Sun 05 Nov 06 @ 11:54 pm
no but I am useing FlyakiteOSX
FlyakiteOSX is a transformation pack. It will transform the look of an ordinary Windows XP+ system to resemble the look of Mac OS X. The installer simply automates the process of replacing critical system files, setting registry tweaks, and installing extras such as cursors, sounds, visual styles, etc.
geposted Mon 06 Nov 06 @ 12:21 am
what can I try
what can I try
add me to your msn
dj quintana
geposted Mon 06 Nov 06 @ 1:32 am
Can anyone tell me more about what I should be trying?
geposted Mon 06 Nov 06 @ 9:45 pm
you might have damaged some dlls with that pack
geposted Mon 06 Nov 06 @ 9:48 pm
It does not work on my laptop and it does not have the mac patch on it
geposted Mon 06 Nov 06 @ 10:04 pm
u added him?
geposted Mon 06 Nov 06 @ 10:27 pm
What are the settings supposed to be in the BCD driver control panel? I'm experiencing some lockup issues (not the ASIO driver issue)
geposted Mon 06 Nov 06 @ 11:32 pm
I was able to get to work on my laptop but still I get a asio sound drive erro on my desktop I don't get it at all.
geposted Mon 06 Nov 06 @ 11:44 pm
