Topic: Suggestions please.
jenhenPRO InfinityMember since 2004
Can anyone suggest a soundcard to use with VDJ? I am not using TCV or anything else just a laptop and a mixer. I would like to be able to pre listen to song so I can mix better. I have heard about the Maya44 but I am thinking it may be more than I need since I wont be using anythong but my laptop and mixer. Thanks in advance.
Sean
geposted Mon 06 Nov 06 @ 3:29 pm
sbangsPRO InfinityMember since 2004
geposted Mon 06 Nov 06 @ 3:59 pm
socrossPRO InfinityMember since 2004
Gigaport AG - this card is rock solid!
geposted Mon 06 Nov 06 @ 5:18 pm
DJ-ALFPRO InfinityModeratorMember since 2005
The cheapest way is to get Sound Blaster Live USB, it is around 60$ and you have all you need, I use it and I don't need TCV's also, like you.
geposted Mon 06 Nov 06 @ 5:39 pm
xeonPRO InfinityModeratorMember since 2004
U46DJ - you can have it for TC use too ;)
geposted Mon 06 Nov 06 @ 5:47 pm
Thanks I will reaseach them all
geposted Mon 06 Nov 06 @ 6:47 pm
