Forum: Old versions
Topic: Language selection on .VOB files
Hi there,
I want to use VirtualDJ for playing my karaoke DVD's.
On a karaoke DVD there are several language/audio selections possible.
On a normal DVD player you can select between the track with original vocals, or without. So in case you have really bad singers you can select the track with the original vocals.
I have searched the guide, forum and the internet but coudn't find an answer.
So my i'll place my question on this forum.
Thanks in advance,
Jeroen
geposted Wed 08 Nov 06 @ 1:22 pm
Nobody had the same problem?
Maybe if the feature is not yet in VDJ then move the topic to the sugestion forum.
Jeroen
geposted Mon 13 Nov 06 @ 12:20 am
TBone29Home userMember since 2006
This is the feature i'm looking for as well. I have many DVD karaoke I'd love to use VDJ for karaoke application.
geposted Fri 01 Dec 06 @ 1:56 am
