I have a question...Im debating between CDJ800 mk2 or ICDX by numark. i have two questions.
If i use the CDJ800's i have to use tccd's but i LOVE the fact that they have a quick return cue function when you touch the platter which is awesome for scratching into a new song.
Can the numarks do the same thing when connected to vdj? are they just as sensitive with the touch platter and do they have the quick return cue function?
geposted Sun 12 Nov 06 @ 6:53 pm
yes they do. and they would be much better control too because its a direct usb connection and you dont really need to use any timecode. but make sure you also purchase a full version of vdj to gain access to all the features and are not limited to the extent of the trial.
geposted Mon 13 Nov 06 @ 7:57 am
DJKice wrote :
Yes they do
Please, explain how, I have them since last week, I haven't found the config to do it
StayFr3sh84, iCDX are great. worth every € I spent on them. I had my first gig with them last weekend and I love them. used them with mp3s DVD and HD flawlessly. I haven't tried it deep enough with VDJ.
geposted Mon 13 Nov 06 @ 11:51 am
burn time code cds
that way you can control it via the icdx
geposted Mon 13 Nov 06 @ 12:07 pm
you said "Yes They do"...You mean that Yes they have the quick cue return function???
geposted Mon 13 Nov 06 @ 2:07 pm
yes
geposted Mon 13 Nov 06 @ 2:24 pm
