a friend of mine has the pro version. how can i do it directly from the virtual dj to push a button when i want to talk and the music decreases?
    geposted Mon 25 Jun 07 @ 8:36 pm
          you need it your not allowed to use his copy
enable talk over on the console soft and when you turn the mic on by pressing the button it is reduced
i hope to see you as a pro user soon
geposted Mon 25 Jun 07 @ 8:40 pm
          we want to broadcast from my friends computer, he doesn't own hercules and he wants to do it directly from vdj so please someone answer my simple question. thanks
    geposted Tue 26 Jun 07 @ 2:13 pm
          he should use his acount to ask then..
    geposted Tue 26 Jun 07 @ 2:21 pm
          why you just can't answer my question?
    geposted Wed 27 Jun 07 @ 12:03 pm
          anyone please?
    geposted Sat 30 Jun 07 @ 10:54 am
          how do u broadcast?
    geposted Thu 02 Aug 07 @ 3:01 am
          Can one use Mac Virtual DJ for broadcasting too?
    geposted Thu 02 Aug 07 @ 5:04 am
billy_44 wrote :
how do u broadcast?
check page one of this guide
geposted Thu 02 Aug 07 @ 12:34 pm
yes its all the same setup :)
          Sky
I have opened ports in windows firewall and I just have a USB modem.
When I try to broadcast it says "Error" "can't listen on port 8000"
Any ideas what I can do next.
geposted Sat 04 Aug 07 @ 10:49 pm
          who is your carrier? they can block ports on their end too
for example aol ban server ports unless you request them.
geposted Sun 05 Aug 07 @ 12:22 am
          You may have to purchase a modem/router, I am not sure if usb modems can be configured as your requirements.
Mike
    Mike
geposted Sun 02 Sep 07 @ 6:43 pm
          Can anyone help me , i am trying to broadcast using mk2 console and virtual dj. I try to use Shoutcast at which point i see that a Encoder is required. I don't know what should used in the Encoder section. I am running through a netgear modem router on a broadband connection, i see everyone mentioning port openeing, but i am assuming this is only used for streaming to a server which i do not want to do. Would appreciate some help
    geposted Tue 11 Sep 07 @ 6:58 pm
          download the lame encoder and place it in C:/programfiles/virtualdj
http://www.free-codecs.com/Lame_Encoder_download.htm
geposted Tue 11 Sep 07 @ 7:05 pm
          i have downloaded the encoder and saved it to the path file you saved it but i can't seem to find it when iam looking in virtual dj  folder, and nothing goes into my encoder section
    geposted Tue 11 Sep 07 @ 7:15 pm
          do you think i need winrar to open the encoder as it comes as a zipped folder
    geposted Tue 11 Sep 07 @ 7:18 pm
          yes extract that and copy the lame.dll to the virtualdj program folder
    geposted Tue 11 Sep 07 @ 7:56 pm
          I have put the .dll into virtual dj and that has changed the end of the link to virtual dj.mp3 ,but i still cannot log to the link is there anything i need to be changing on my router and if so does it affect my day to day normal use of the internet ?
    geposted Tue 11 Sep 07 @ 8:30 pm
          look in the config and forward ports 8000 and 8001
do the same in the firewall :)
geposted Tue 11 Sep 07 @ 9:21 pm
