Topic: Hey Cyder- quick question about VMIX skin
HoffmanPRO InfinityMember since 2006
hey Cy,
Do you know the feature in VDJ that says "use this plug-in for audio only files"?
let's say you have it on sonique- this is very cool so that everytime you are not playing a video it will go to sonique.
But in the course of a night, as a DJ/VJ you may want to black out the place, put up just text, or other things while there is audio on, but not want soniques running all the time.
Would it be possible for you to add soemthing to your #1 VMIX skin which allows us to make a shortcut key to turn that function on and off when we want?
any info would be great-
thanks and keep up the great work.
B
geposted Tue 14 Nov 06 @ 2:53 am
phillydjPRO InfinityModeratorMember since 2004
you can just got to the effect browser od the skin and dim down the sonique
geposted Tue 14 Nov 06 @ 4:11 pm
HI,
no, i don;t think this will work becuase once you put the setting on "play this plug-in (sonique) when audio is on", you can't dim or shut off the sonique unless you go back to that setting.
try it, please let me know.
B
geposted Wed 15 Nov 06 @ 12:08 am
