Topic: gettinf frustrated
So i have the Mk2 w/ the Home Edition and TCV. i try to setup the TCV during the 5 minute period in the Home Edition and get TCV not detected error.
SO..... i goto a completely diff computer that never has had VDJ loaded on it.. we download the 4.1r trial version.. hook up the Mk2.... install all the new versions....
fire it up set it up like skyfxl directions and WALAA....... no TCV detected.
get 0% and silent on config.
WTF is going on??? i plugged unplugged replugged all cables!!!
STANTON STR8-80
SK-6 Mixer
Stanton headshell.. im not sure of the needle.
when software is installing i can hear the windows pop-ups through the speakers connected to the Sk-6 mixer!!!
geposted Wed 15 Nov 06 @ 4:44 am
Don't slit your wrist yet. I am sure one of the TCV guys will be here to help you out.
Did you GROUND your TURNTABLE to your PC's Casing or to your Mixer?
hmmm... i did not ground turntable.
is there a special wire or can i use any wire to ground?
also i see the ground screw on the mixer but not the turntables... where do i run it from on the turntables??
in STANTON STR8-80, it's right beside the RCA.. you can use any kind of wire to connect it to the mixer.
I am laughing my ass off. Yo, I feel your pain, but this is funny. I told you help was on the way.
@carter: to put it sinple u cant register the program; HOWEVER , if u bought your mk new u cab enter the serial for that and it will show that u have the hercules
i had bought one off a guy in N.Y but i couldnt register it si u sold it and later i purchased the program (its not that xpensive ) trust me the program will pay for itself with one gig and its well worth it
however good luck w/the gig u should b tight...jus b creative
hi is it fixed now?
if not drop me a email at admin@skyfxlmedia.com or add that adress to your msn :)
email sent.....
thanks mate as i said in the email i think your cable is damaged
one more quick question..... if i go out and buy the u46dj thing
can i use it to test the TCV w/ Home Edition. i really want to get this thing working to see if i want to spend money on the full version
TCV doesn't work in HOME EDITION.
doesnt it give you 5 min test period???
It does give you five minute testing to one deck, but as far as I know the hercules mk2 and dj control are the only supported hardware in the 3.4 DJC edition (home edition). However, you do get a discounted price on pro edition for having registered the mk2/ dj control;^]
ok thanks for all your help guys...
i got new RCA cables
grounded the mixer.
and now it almost works perfectly.
2 NEW questions...
i am using the 4.2r demo and both turntables/songs are coming out of on a single channel (the same channel) on the mixer instead of being seprated left/right
and the sound is choppy just regular playing
for the Channel Problem.
Make sure you set Ch1&2 for LEFT and CH3&4 for RIGHT.
For choppy sound.
Go to Performance and move it all the way to the LEFT (Fastest) then gradually move it right until you find the BEST and non-choppy quality. Now, if non works, it's best to leave it to Fastest
thanks about the channel info...... that is the box that says input channels in configon the bottom for 1,2 left and 3,4 right???
yeah i checked that.. but it seems like both turntables want to play through one channel.
is there another setting in the mk2 that needs to be made??
THANKS IN ADVANCE for all the help!!!
You were talking about INPUT
For the OUTPUT...
Put Ch1&2 (LEFT) & CH3&4 (RIGHT) -- OUT (FROM MK2) to the INPUTS OF YOUR MIXER. (ie. line1 for (CH1&2) and line2 for (CH3&4)
I don't own a Hercules MK2 so I really don't know.. But I'm guessing that's how it is.
please check ur setup against this
and ur phono cables
