I was SPinning a Live gig for My radio stations.... I was playing 2 tracks at the same time. I used the Beatgrid on Left Deck... When the 8 beats were just about up I hit Beat Grid on Right Deck using the buttons on the controller. As soon as I hit the Effect button (FREEZE_) cpu locked up. VDJ Not responding.. I was very very upset. Please can this bug be addresses for future releases.
I have
Pavilion Laptop
AMD 64 (2.6ghz)
2GB Ram
128mb Video Card
240 GB Hard Drive
Behringer BCD2000 Controller
TCV
I have
Pavilion Laptop
AMD 64 (2.6ghz)
2GB Ram
128mb Video Card
240 GB Hard Drive
TCV
geposted Wed 15 Nov 06 @ 4:07 pm
has this ocured at least 5 times?
what esle where you running at the time?
there are some known issues with bcd2000
im not sure about this one have you done a search of the forum ?
what proformance settings are you using
geposted Wed 15 Nov 06 @ 4:10 pm
This is an occurance that I can make happen always. It has happened 17 total Times.
It doesnt madder what effect you use. if you use 2 effects at same time it will happen. Now you have to have both decks playing A & B
I have been using VDJ from Trial Version 1.09, I saw 4.1 released and bought it. I read forums on daily basis. I have all teh Correct settings in CONFIF. I have read the Blogs all teh time.
Ok I was mixing 2 Tracks...
geposted Wed 15 Nov 06 @ 4:49 pm
The bug is so bad that 45% of the time my laptop will Blue Screen of Death.
I am using Skins, DAC 3 +4.1 Skin, I have also used the Mini Scratch, and VDJ Normal SKin. I thought it was a skin bug but it wasn't.
geposted Wed 15 Nov 06 @ 4:52 pm
could you post a screenshot of your soundconfig and proformance sliders
using www.tinypic.com
geposted Wed 15 Nov 06 @ 4:58 pm
CONFIG 1
CONFIG 2
![](http://i15.tinypic.com/2nro4xt.jpg)
CONFIG 2
![](http://i15.tinypic.com/4i3yudk.jpg)
geposted Wed 15 Nov 06 @ 5:50 pm
Do not use bcd as a sound card, USE ASIO , DO NOT USE THE BCD ICON
DJ QUINTANA
DJ QUINTANA
geposted Wed 15 Nov 06 @ 8:00 pm
yeh pic bcd2000 asio
geposted Wed 15 Nov 06 @ 8:08 pm
Will this Stop the crashing when I use the effects at the same time while playing 2 consecutive tracks?
geposted Wed 15 Nov 06 @ 8:39 pm
This only happens to me when I use TWO EFFECTS at the same time.
BCD2000 just Bluescreens in XP and then reboots after 2 seconds.
Did that happen to you flavoredbreaks?
geposted Thu 16 Nov 06 @ 1:02 am
YEAH Thats what happening... and u have to restart the PC
geposted Thu 16 Nov 06 @ 5:16 am
Though this only happens when I use 2 EFFECTS at the same time. My Laptop just goes Bluescreen then restarts automatically. But hopefully this will be solved soon.
geposted Thu 16 Nov 06 @ 5:53 am
Yeah I had disabled my wireless, Lan, Modem, CD-Dvd RW +/-, and when I use to play 2 tracks simultaneously, and then use 2 effects simultaneous The VDJ software will Freeze, song will still play, then BAM BLUE Screen of Death. CPU Shuts off. It starts in 7 seconds , but thats 7 seconds of quiet down time a DJ Should never Have....
geposted Thu 16 Nov 06 @ 7:16 pm
Yeahp!
That's exactly what happens to me too.. But luckily, I don't use 2 effects at the same time with my style of DJing.
This is a Driver Issue not VDJ. So we just have to wait for a better driver.
geposted Thu 16 Nov 06 @ 11:16 pm
Everybody's waiting for that update.
geposted Fri 17 Nov 06 @ 4:37 am
there is a known issue with the effects/midi, and new update should resolve the problem. alot of us with the nuo4 are waiting for the update.
geposted Fri 17 Nov 06 @ 5:26 am
Oh... so it is a VDJ problem, is it?
geposted Fri 17 Nov 06 @ 7:04 am
HEY THE KEY thing is that we Know the VDJ TEAM Will get us an Update Guaranteed, but as for Behringer .... Well your better of humping a monkey, to get a response from them
geposted Fri 17 Nov 06 @ 3:32 pm
Oh so this \"2 Simultaneous Effects\" problem is caused by VDJ and not by the faulty Behringer Drivers?
geposted Fri 17 Nov 06 @ 9:46 pm
I want to know "WHAT IF"
Coders/Programmers from VDJ Community modify the BCD-2000 Drivers and make it more stable with VDJ. If Behringer can't do a good job about it. Why can't VDJ Programmers/Coders make their own drivers for it OR modify the current drivers from Behringer?
geposted Fri 17 Nov 06 @ 9:51 pm
