Topic: Dac 3 Pitch bend
Hi, I just received my new dac 3 today, gotta say it is very good, one slight thing I dont like & I wonder if it can be changed is the pitch bend sensitivity settings. Can this be changed if so does anyone know how?
Many Thanks
geposted Wed 15 Nov 06 @ 8:34 pm
Which mapper are you using?
Im using version 1.4
If you are using my custom DAC-3 mapper, you can adjust the pitch bend sensitivity using user parameters (See the end of the DAC3Mapper manual in the .ZIP file you downloaded.)
The parameters to adjust are:
23 Fine pitch bend sensitivity - Adjusts the sensitivity of the -/+ pitch bend buttons. The default is 128. Set to a higher value (E.g: 256) for greater pitch bend or lower value (E.g: 64) for a more finer pitch bend.
12 Jogwheel pitchbend sensitivity - Adjusts the sensitivity of pitch bend using the jogwheel.
Many Thanks, Can you tell me where in the config menu I can find the section to change the pitch settings?
Have done it, many many thanks
