Forum: Old versions
Topic: Windows Virutal Memory tool problem!!!Need HELP!!!!!
Hey guys,
I have a labtop which I use for vdj. I use Windows XP. I have 2.4ghz and 40gb harddrive. A pentium 4. and have modified the labtop for vdj. For some reason in the last few jobs I did the labtop has pop up with a little ! point in a yellow triangle sign. When I place the mouse over it, it says, virtual memory tool minimum is low. And then it disappears. but it doesn't stop the program nor make it act funny from what I've noticed. I'm just scared of my computer crashing in middle of a job. Please if anyone has any clue what that means or what I can do, please help me.
geposted Thu 16 Nov 06 @ 6:05 am
Don't really know if this is windows pop up window. Check you computer for spam programs.
as a certified computer geek
i can tell you this means your swap file is to small and your pc is being over tasked
go to my computer right click and press properties
then you will see a tab called advanced
now you will se a box called proformance press settings
and on this menu go to the advanced tab
and go down to virtual memory
and press change
pic custom size
and put a minum level of 1000
and a max of 2000
and press ok
you will be prompted to restart
do and the problem will be solved
I had that set to 256 and never get this msg.. maybe it is this what is he talking about. but rather set booth values to same number.
no you musnt
the lowest is the lowest point you select
this is the smallest the pagefile is alowed to go
the max is the max it can have of disk space if you pick the same
the page file cant expand you you will get errors or poor long term proformances
Hey
I also use a laptop and have found this little freeware tool
http://www.yourwaresolutions.com/software.html#framxpro
It's fabulous... you have to play a little with the settings if you want max performance from it but it is a ronseal product(Does exactly what it says on the tin!!!!!!) and the default settings work great.
I have had no problems with it and it runs perfectly on my lappy together with VDJ
might be of use to ya
also a good thing to do is to clear the startu from unnesecary software ( also the services ) just press start and then run :P just type msconfig and go to the startup thingie..I´ve disabeld all mine startups and some of the services during the boot..the result is a faster and more stabel computer :P
Think we´re two geeks ( work as a supporttechie for fujitsu siemens computers )
Thank you guys sooo much. Today is Saturday the 18th in Miami. I hae a party to do tonight. I am going to make the changes and will definitely let you guys know whether your suggestions worked. As for the two links that you guys left, I'm sorry I'm no where as tech savy as any of you guys so my questios is, what exactly do those programs help do?
increase the virtual memory
Hey guys, just wanted to inform you that I changed the virtual memory settings like you guys said and on Saturday I played for about 6.5 hours straight and had no problems. Thnak you soooooooo much for your help. As for the links again, they help increase virtual memory? Should I download them?
I also have a new question, I have had this issue ever since I been djing. When I have no sound playing and I have my speakers on all I hear is this radio staticky sound. The moment I unplug the labtop the static goes away. I've been told that I need a POWER CONDITIONER. I was referred to FURMAN, but I honestly have no idea which to get or what specs it should have or how many AMPS or anything. So does anyone know what I should get and any suggestions on brand or quality. Thank you guys again.
