Topic: Vob & Cdg Files
Is Vob The best way to rip Video Files? Cdg Files? Either Grab to bin, cdg, cdg+wav or cdg + Compressed File?
Thanks
geposted Fri 17 Nov 06 @ 4:26 pm
phillydjPRO InfinityModeratorMember since 2004
For CDG Disc, it's best to convert to Mp3+G then zip (takes up alot less room)
For videos, if room isnt a problem VOB is the best way to go
geposted Fri 17 Nov 06 @ 4:31 pm
How do i do it? Mp3+g then Zip? Audio Grabber says it puts them in a Mp3+g. I still get 2 files. One Audio & Graphics? Without using VOB Files, is the Quality of the Picture not very good? Also, How do i put the Video or Karaoke files in Order in the Browser?
Thank You
geposted Fri 17 Nov 06 @ 5:46 pm
Use Mp3+G toolz, it takes .bin or audio + graphics and converts to zip and best of all it's free
mpeg quality is good , In my opinion I notice a diffrence between VOB and Mpeg only on bigger Tv's or HDTV
geposted Fri 17 Nov 06 @ 8:09 pm
What about Quality on using Projectors?
geposted Fri 17 Nov 06 @ 8:29 pm
For a very good explanation of converting cdg discs see the blog of pcgumshoe.
Ewout
geposted Sat 18 Nov 06 @ 10:42 am
