Forum: Old versions
Topic: mp3 recoding in vdj 4.1
trez777Home userMember since 2006
i am able to record my mixes in mp3 format using vdj 4.1. upon playback, i noticed that on any of the incoming track, you hear first a bass sound (the low - as if the low was on full) then suddenly it goes back to normal and then you hear the incoming track play (i usually bring down the low and mids on any incoming track then full it during blend/transition).
how can i solve this problem and get rid of the low sound on my incoming tracks? i dont hear this during live mix -- only on playbacks.
geposted Sat 18 Nov 06 @ 10:04 am
sbangsPRO InfinityMember since 2004
watch the eq settings
what format are you recording to?
geposted Sat 18 Nov 06 @ 12:47 pm
recording to mp3 format. i always put the low and mid eq's to 9-10 o clock setting for incoming tracks. they sound good (no bass) on live mixing but upon playback of recorded mp3, there's always a low on the background that appears.
geposted Sat 18 Nov 06 @ 1:49 pm
any help peeps?
geposted Mon 20 Nov 06 @ 4:24 pm
what do u have on those settings
geposted Mon 20 Nov 06 @ 8:18 pm
exactly the same thing as posted in the pix:
auto gain -- always match
pitch range -- -34 to +34
geposted Tue 21 Nov 06 @ 2:28 pm
anyone getting the same problem? basically i cant get a good mix because for all incoming tracks i hear a low bass sound then immediately disappears (as if the bass of the incoming track plays) -- even if i set the low eq to 9 o'clock. i might be thinking it could be grounded. im using dj console 1 and vdj 4.1.
geposted Wed 22 Nov 06 @ 1:44 pm
does it do this with all or just some songs?
geposted Wed 22 Nov 06 @ 2:36 pm
unfortunately all songs. i dont know if theres a ground or something and perhaps during recording it picks up the low eq/bass in split seconds. any other suggestions? is this the first time someone raised this issue?
geposted Wed 22 Nov 06 @ 3:59 pm
which engine did you use to scan your files
any music or techno ?
first time iv heard of it will do some thinking
geposted Wed 22 Nov 06 @ 4:26 pm
just chose techno/house. while thinking i might try to do some recording using an external program. any suggestions? should audacity do the trick?
geposted Wed 22 Nov 06 @ 4:53 pm
try this one
www.applian.com/freecorder
if there is a base eq problem
in this recording
u need to lower the eq on vdj mixer
geposted Wed 22 Nov 06 @ 4:56 pm
