Forum: Old versions
Topic: Longer loops in virtual dj?
I would like to use longer loops in virtual dj, how can I program the buttons 1,2 and 3 to loop longer?
geposted Tue 21 Nov 06 @ 2:37 pm
thus u need to buy pro
really? then I can set the loop to 8 for instance?
Hi..you can actually do it in the home edition.
1.Let the interface display the loops section
2.Click on the loop button for where you want to loop
3.Increase the figures in the loop section window (this is normally set to 4, so you can use the arrows to increase the number from 4, 8, 16, 32, 64, (or 100 if you ever needed a loop to go on that long).
Regards
DJ Yemi
cool i forgot about that
but if u want to map the loops to longer you need the mapper for pro users
u can aslo make keyboard shortcuts for this is want to triger a longer loop :)
