Hi All,
I posted the post "FORGET ABOUT LAPTOPS" Dont get me Wrong, laptops are fine (I just dont use one) So for all the LAPTOP users. in my travels (online) I found this "FIRE BREATHING MONSTER" If I was getting a laptop it would be one of these :-) its suited for the task nicely !
SPECS:
ITC Millenia 7300
5.6kg<monster!
NVIDIA GeForce Go 6800 Ultra 256MB (The graphics can be upgraded too)
3.6GHz Mobile Intel Pentium 4 800Mhz fsb processor with Hyper-Threading
1GB/2GB 533MHz dual-channel DDR2 SDRAM
2 80GB 5400rpm SATA hard disks
Built-in analog TV tuner with a remote control
Built-in 640 x 480 Web camera
4 USB 2.0 ports
CONS> HEAVY, HOT, VERY $$$, LOW BATT LIFE (but for gigs it would be pluged in the wall anyway) !
(BUT IT WOULD CRANK)
3DMark05 score of 5077 and a high PCMark04 benchmark of 5266
![](http://www.pcworld.idg.com.au/im.php/width/640/im/524_7_itc_millennia_7300.jpg)
SPECS:
ITC Millenia 7300
5.6kg<monster!
4 USB 2.0 ports
geposted Tue 21 Nov 06 @ 5:55 pm
omg please tell me your not considering buying from pc world lol?
geposted Tue 21 Nov 06 @ 10:29 pm
no im not gettig one ! WHAT DO YOU MEAN THO ?????
Chris
Chris
geposted Wed 22 Nov 06 @ 5:12 am
pc world are totaly incompetant
and charge totaly unreasonable prices
for example
this morning i was looking for a monitor power cable
maplin electronics £1.99
pc world £15 !!!!!
for example
pc world £15 !!!!!
geposted Wed 22 Nov 06 @ 10:39 am
OMW pentium 4 for the suck :/ if you want something to keep your food warm while you there, then you got yourself a winner :D
geposted Wed 22 Nov 06 @ 11:39 am
^^^^^ is there a word missing or is it just me ??????????????? you dont mix with your latop on your "LAP", let it make the table HOT ! get a fan !.................... :-)
geposted Wed 22 Nov 06 @ 2:12 pm
the hotter a laptop gets the slower it is for that model ul need an external cooling system for sure
geposted Wed 22 Nov 06 @ 2:44 pm
Its a 3.6 mzh cpu its not going to slow down alot, external cooling a laptop with the loads "MUSIC/VDJ" puts on , would be a "standard" add on if you used it for this purpose, even DUAL CORE cpus get very hot after being on, playing music all day .
Thats all nitty gritty stuff anyway, The point is find a "powerfuller" laptop if you can, after all we allways want more POWER !!!! :-)
ChrisB
(I get hotter than my cpu, jumping around/dancing, when im behind the mixer!!!!) lol
ChrisB
geposted Thu 23 Nov 06 @ 2:18 am
geposted Thu 23 Nov 06 @ 10:43 am
i don't know why u got to put down laptops for,i think u just got to get the right one for what you are going to do many of u guys are just looking at speed memory is very imporant also that's what i run into when i bought a laptop three years ago the max memory was 512,most laptop have a max of 2gb memory but with win vista soon out you can use any amont u want just plug in say a 4gb usb flash drive win vista will use that also as memory.a rackmont pc is fine and batter i were just about to put one together a good rackmont pc will run about $2000 so i'm thinking this or laptop.
geposted Thu 23 Nov 06 @ 5:10 pm
ITS NOT A "LAPTOP", I think of it more as a "MOBILE DESKTOP" ! lol (well thats whats inside)
geposted Fri 24 Nov 06 @ 12:14 am
