Topic: this may be a odd question
in absolute mode in vdj with tcv if u if u bump the needle will u hear the skid sound it makes when bumping the needle across?
geposted Fri 24 Nov 06 @ 12:51 am
No you won't. The needle is not picking up everything on the TCV, it's only picking up the signal that drives VDJ.
geposted Fri 24 Nov 06 @ 12:58 am
Dj XeoPRO InfinityMember since 2005
in any mode you will hear the skip but in reletive mode (or any mode but with anit skip enabled) the music will carry on where it left off. in absolute mode with no antiskip if the needle moves position the song will move there too. so if you jump 4 groves over the song will move about 2 seconds ( antiskip can fix this if its enabled but will mess up the absolute position and hence not be truly absolute.
use good and well setup euipment professionaly and you will never have a needle skip
geposted Fri 24 Nov 06 @ 1:01 am
is it posible to make tcv where the turntables reads everything in stead of just what drives vdj?
geposted Fri 24 Nov 06 @ 1:16 am
cuz i would love that tcv turntable that reads everything on the tcv i would hope this is posible please post if it is and even post even if it isnt cuz maybe the dev team will look at this and take in consideration!
geposted Fri 24 Nov 06 @ 1:23 am
sbangsPRO InfinityMember since 2004
do you mean being able to play real vinyl?
geposted Fri 24 Nov 06 @ 10:38 am
the way it works is that its reciving a signal of
10101010101010 which when it stops
the computer knows to stop the
im not sure if it would be possible to add what ur mentioning
but if you move the needle along the record from say 30 secs to 120 secs
the song jumps 2 but
im not sure that is an advantage
infact there is an anti skip option to prevent this
geposted Fri 24 Nov 06 @ 2:44 pm
I don't think it's even possible, it like goes against the laws of reality. It wouldn't make sense. I can't think of any way that would work.
@wessmith, actually skyfxl is kinda right. That would be a disadvantage.
geposted Sat 25 Nov 06 @ 12:22 am
