Since installing 4.1 my VDJ has been freezing and I didnt know why. My search has revealed that during the mix the CPU usage is topping out at 100% and then freezing. In the past there would be a rise but never that high. My machine is a 3200 Mhz AMD with 512 Ram so it cannot be the machine. Your thoughts please.
geposted Fri 24 Nov 06 @ 8:01 pm
you have a fast processor yes
but in relative figures a small amount of ram
so try lowering your proformance tab
geposted Fri 24 Nov 06 @ 8:06 pm
I am having similar problem on my AMD based laptop. Even when no songs are loaded, I takes 30% of the CPU. Something else is going on, and I haven't figured it out. I get 0% cpu usage on my other Intel based laptop. I didn't get this problem before.
geposted Sun 26 Nov 06 @ 7:21 am
try some optimisation tools
http://www.theorica.net/gamexp.htm speeds up proformance
http://www.theorica.net/gamexp.htm stops unnessary services
geposted Sun 26 Nov 06 @ 12:07 pm
Try diableing the video acceleration in your video card settings. laptops have a problem with that issue. Your cpu should stop maxing out after that.
geposted Sun 26 Nov 06 @ 5:23 pm
not sure if thats related aslo becareful with this setting because im told in some cases it can make it worse
geposted Sun 26 Nov 06 @ 5:32 pm
have you run a full disk derag recently?
dont use the built in one with xp its useless
try www.diskeeper.com
geposted Sun 26 Nov 06 @ 5:33 pm
I am talking about your display settings in the control panel. Go to settings then advanced and under troubleshooting run the hardware acceleration slider all the way over to the none position. This will reduce the load on the cpu.
geposted Mon 27 Nov 06 @ 4:18 am
kool see what you mean that should help
run a defrag aslo to be sure
geposted Mon 27 Nov 06 @ 10:49 am
Hay did that setting work cause i'm having a problem after 1 hour of play my vdj freezis up too soo i am going too try that and see what happens. my specs are 2g ram, AMD turion dual core, 120 gig hd and 1.8 g hertz hp pavillion 9010 series
geposted Wed 06 Dec 06 @ 4:04 am
I'm using VDJ 3.2 with the MkII, when ever I use the effects it crashes also after about two hours it freeze can anyone help?
geposted Mon 08 Jan 07 @ 11:51 pm
is your computer getting hot check here
http://www.virtualdj.com/forums/62980/Software_Technical_Support/vdj_crashes___and_your_computer_is__slow___or_getting_overly_hot__check_this____.html
its is often a cause of proformance issues
try the tweaks here aslo
http://www.virtualdj.com/forums/62907/Software_Technical_Support/Asorted_Software_Guides__(common_fixes_and_tweaks_and_how_2_s).html
geposted Mon 08 Jan 07 @ 11:54 pm
Also, if you have video preview windows that are active on your screen, they may pull some CPU power too. even if no decks are playing.
geposted Tue 09 Jan 07 @ 12:26 am
When I just start up VDJ, and use the effects it still crashes I think it's a software problem.... I've been only using the my laptop in the bed room which isn't too hot.........
geposted Tue 09 Jan 07 @ 12:32 am
Are you using the Hercules DJC mapper? There is a bug with that where when you enable it in WDM (non-asio) mode, it uses a whole lot (if not all) of cpu. The workaround is to always be sure that VDJ starts in asio mode and then change it to WDM (standard) mode once it is started. This means always switch the Hercules to asio before cloing the program. Changing the mode is done under the 'sound card' tab of the setup screen.
DJ Cel says he will be coming out with a fix for the mapper, but the workaround works ok for me for now.
geposted Tue 09 Jan 07 @ 8:42 pm
he shoudlnt be as hes a home user ;)
geposted Tue 09 Jan 07 @ 8:49 pm
