Hey i want to become a DJ and i want to know what equiptment i need. Please help me out
-Purse
-Purse
geposted Fri 24 Nov 06 @ 10:26 pm
do you wana be a digital dj and use virtual dj ?
or do you want to be a vinyl dj only?
or do you want to do both?
geposted Fri 24 Nov 06 @ 10:27 pm
well i want to DJ at parties so what would be best?
geposted Fri 24 Nov 06 @ 10:40 pm
at home parties
you would be fine with a laptop
and an mk2
http://www.virtualdj.com/products/hardware.html#djc2
and a small pa system
http://www.themusicking.co.uk/proddetail.php?prod=559&nav=47
and an mk2
geposted Fri 24 Nov 06 @ 10:51 pm
the dj console comes with vdj home
if u wanted to take your mix furhter you could upgrade at a reduced cost
then you could have features such as
http://www.virtualdj.com/products/timecode/
if you bought decks and the timecode vinyl
geposted Fri 24 Nov 06 @ 10:53 pm
hello i just descover night club one year ago and i love mix that you find their. i ask santa claus to bring me a dj equipment but i don't know exactly what i should buy
is it better to start with only something on the computer or is it obligatory to have physical equiment?
digital dj is i think the best for me
geposted Wed 06 Dec 06 @ 7:03 pm
i started with mk2 then upgraded and moved out through the other product ranges
geposted Wed 06 Dec 06 @ 7:32 pm
what is MK2? i m a beginner in mixing
geposted Wed 06 Dec 06 @ 10:04 pm
geposted Wed 06 Dec 06 @ 10:06 pm
ok I found out what is an MK2.
i want to mix from original music so making mix from mix is it still good to have an MK2?
geposted Wed 06 Dec 06 @ 10:08 pm
yes u can use vinyl and mp3 to mix
but ul need virtual pro
geposted Wed 06 Dec 06 @ 10:19 pm
Hi. I want to start djing in a club that had there own speakers. Can you tell me what I will need, and what i should do to learn?
geposted Sun 19 Aug 12 @ 12:48 am
hi i want to start djing , in clubs or whatever comes along the way , and eventualy make my music someday. my question was , seens i want to be a digital dj , what cdj's are better for me to start out with. any coment will b helpful thank you.
geposted Tue 28 Aug 12 @ 6:45 pm
Why did you post in 'mix lessons' if you're asking about equipment?
And also posting on the end of a six year old thread....
Anyway, if you're planning on using computer software (I guess that's what you mean by "digital DJ") then you don't need CDJs.
They're primarily CD players, they're very expensive and they've overkill if you're using software.
What's your budget?
What's your budget?
geposted Wed 29 Aug 12 @ 9:35 am
hello eveyone , i have a quastion abaot DJ-ing , first of all : I started to mix a songs abaot 7 days ago , and i have some idiea's that can be used as a mix .
I have a Virtual DJ 7 Home free on my PC , and that thing working normaly , but lets get back to deal ....
how can i make a mix to my favarete club SalentoDiscoPub , using the Virtual DJ 7 and music traks from my playlist , that you can find on :
http://vk.com/id175742728
PS: i;m a beginer in a club mixing .
Regrats , mark .
Regrats , mark .
geposted Wed 29 Aug 12 @ 3:16 pm
Just posted a guide/tips topic: http://www.virtualdj.com/forums/168198/Hardware_Technical_Support/DJ_Guide__How_to_get_started_%28What_gear_to_get_%29.html
geposted Wed 29 Aug 12 @ 5:06 pm
many regrats lad , i will keap this link in the favoret's bar . tnx .
geposted Thu 30 Aug 12 @ 4:34 am
Look what ever equipment you want to start with you can get here [LINK REMOVED]...
[Advertising is not permitted on the VirtualDJ forums. Please read the forum rules]
geposted Mon 24 Sep 12 @ 8:21 am
I'm starting a part-time DJ and light show business, any tips would be great. I used to do this back in High School, with VICA, but it seems like a lot has changed since then.
geposted Wed 10 Oct 12 @ 4:28 pm
It´s up to you how much money you want to spend on the hardware. Hercules DJConsole MK4 is a reliable and low-priced controller with VDJ LE and a build-In sound card. The AA VMS2 is the next step. The controller has a analoge Mixer/ XLR outs/ Booth out/ Mic In/ icludes a very good and powerful sound card and you can choose if you want to play digital tracks via USB from a hard disc or switch to external inputs like CDJ`s.The VMS comes also with VDJ LE. Both are 2 Deck Controllers. The AA VMS 4.1 is a very good 4 Deck Controller.....
geposted Tue 23 Oct 12 @ 2:27 pm
