Now i'm Use VDJ 4.1
And i want to use it mix the music video and show the output on the screen.
the question is how to config the software and show the output screen on outside.
ps.it's like when we mix the song we have to cue the song and when we cue another ppl
will not hear right? just the same way but change to music video
thks for help
thks for help
geposted Fri 01 Dec 06 @ 2:29 pm
Cueing will work the same as with audio. You need to configue your graphics card to allow a second output if you want to display on a second screen (extend desktop)
geposted Fri 01 Dec 06 @ 4:11 pm
yeah i've know about that but i don't know how to configure in the right way
thks for the help
ps. i'm use nvidia FX5200 Card with TV-OUTPUT
thks for the help
geposted Fri 01 Dec 06 @ 6:23 pm
if this no work
does the video out show up in a list of outputs
geposted Fri 01 Dec 06 @ 6:50 pm
You have to do the same for your card. It should say something like Dual View. One should say your monitor, and the other TV. You must have the TV hooked up to the computer before you boot up. Finally, these features may not be available to demo users.
geposted Fri 01 Dec 06 @ 8:20 pm
i have configure it already but my problem is.
i can't show the music video in full screen on TV.
thks so much for everyone help
geposted Mon 04 Dec 06 @ 8:26 pm
In VDJ go to config, then video, then video output, in the pulldown menu, you should have two options. They are (Window) and the next one is your video card. Choose your video card, and then put a check in the activate box. You should be in video heaven. If not, come back.
geposted Mon 04 Dec 06 @ 8:51 pm
Under the options screen, select video...then activate video...then in the frop dow, you can select "window" (then you have to manually resize the window to fit your screen) and "the name of your video card" (your card has to support this feature though).
geposted Mon 04 Dec 06 @ 8:54 pm
Do you use the demo of version 4.1? In the 3.4 demo version it was not possible to view video fullscreen on a second screen.
Ewout
Ewout
geposted Mon 04 Dec 06 @ 9:15 pm
now i'm config like you're all said and it's works !!! thks a lot
but my silly are still with me.
it just only one problem that when it's show full screen video smoothly
it's go on two screen that's mean i can't see my deck to control MV.
plz help
ps.thks a lot for your guys i'm so glad for your help :)
plz help
geposted Tue 05 Dec 06 @ 10:38 am
what proformance settings do you have and what is ur overal pc spec
geposted Tue 05 Dec 06 @ 10:42 am
I Have
Sempron 2200+
Ram 512+256 DDR
A7V600
HDD 80 GB
FX5200 TV-OUT
On Board Sound-Card
I think my spec is ok.
it's about a config or somethin
thks a lot for everyone help again
Sempron 2200+
Ram 512+256 DDR
A7V600
HDD 80 GB
FX5200 TV-OUT
On Board Sound-Card
geposted Tue 05 Dec 06 @ 12:41 pm
