Topic: USB NumPad - HELP
Is there anyway that I could change the behavior of the NumLock in the USB NumPad?
Or. Is there any way that I could disable it?
Next,
Is it possible to make the NumPad to be used as USB Midi Control?
geposted Sat 02 Dec 06 @ 8:57 am
you can use it to apply keyboard shortcuts
how do you wish to adjust the numlock?
I want the numlock to be disabled. Do you know how to disable it FOREVER? ;)
