Topic: Broadcasting to Two Encoders instead of one
CrysisHome userMember since 2006
Hi i need to know how to broadcast to two encoders instead of just the one please.
Thanks in advance
geposted Sun 03 Dec 06 @ 1:15 am
sbangsPRO InfinityMember since 2004
which version of virtual dj are you using?
geposted Sun 03 Dec 06 @ 11:25 am
The latest trial version, but i want to know if what i want is possible otherwise this program wont be any use for me.
Cheers
geposted Sun 03 Dec 06 @ 5:23 pm
all dj programs can only use one encoder at once
if u use shoutcast dsp plugin inshotcast and chosoe soundcard as input u can steam virtual dj output to as many servers as you like
geposted Sun 03 Dec 06 @ 5:26 pm
Use VDJ to login to one and use the sound card into another pc with DSP to login to another server in a different place. With shoutcast you can "Relay" from one server to another by editing the "config"
geposted Sun 03 Dec 06 @ 8:37 pm
The reason im asking this is because for example with the SAM broadcaster program you can add multiple encoders.
geposted Mon 04 Dec 06 @ 12:24 am
its not reali a mixing program tho
it just automaticaly fades ect so u need to weigh up what suits u more
geposted Mon 04 Dec 06 @ 11:23 am
