Forum: Old versions
Topic: Flash Video Files ?
Just thought i'd ask the question, is it possible to play Flash Video Files through VDJ ?
geposted Sun 03 Dec 06 @ 1:01 pm
sbangsPRO InfinityMember since 2004
see if u can add it as a codec
geposted Sun 03 Dec 06 @ 1:10 pm
cstollPRO InfinityMember since 2004
NO
geposted Sun 03 Dec 06 @ 1:25 pm
real player codec and player can play them , wouldnt it be possible to import that
i duno just a thought
geposted Sun 03 Dec 06 @ 1:45 pm
When playing videos in VirtualDJ you have two choices as the decoder - the Internal VDJ engine or using the MS MediaPlayer external engine. Now the internal engine the developers have to code for the support - which currently Flash files are not supported. If you can get a Flash file to play in MediaPlayer now you possibly could say 'Yes'. But, I have not seen anything written to when a flash file can be viewed with MediaPlayer - hence the original NO answer.
geposted Sun 03 Dec 06 @ 2:26 pm
yeh ur right , had a shot at it and no work
but was worth a try tho :)
geposted Sun 03 Dec 06 @ 2:33 pm
Yeah, i second that, i tried also to add as a codec and no joy :(
Maybe somthing to add to the wishlist for future releases though, makes sence to use flash simply because of the file sizes
geposted Sun 03 Dec 06 @ 8:26 pm
Flash files if you don't care about quality????
geposted Sun 03 Dec 06 @ 9:43 pm
yeh flash is low resolution and the audio is bad
geposted Sun 03 Dec 06 @ 9:51 pm
