Forum: Old versions
Topic: Monitoring With Audigy 2 Platinum Front Panel
Hi there,
I'm planning on upgrading my version of Virtual DJ to the pro versio nsoon (got the basic one with my Hercules decks) but I want to make sure I can monitor from the front panel of my Audigy 2 card.
I managed to do it using Traktor and kX drivers, but was wondering if anyone can actually point me in the right direction as to how I would do it?
Cheers.
geposted Mon 04 Dec 06 @ 3:02 pm
acw_djPRO InfinitySenior staffMember since 2005
The Audigy 2 ZS Platinum works PERFECT with VirtualDJ 4.x, but the correct configuration is only available for professional users. You can buy and be sure that you are going to have your Audigy 2 ZS Platinum working 100% and using AUX2 and LINE2 front panel INputs for that ;-)
Once you are a Pro User you can see my blog for that information, or contact me.
Good Luck!
geposted Tue 05 Dec 06 @ 5:56 pm
I just bought this sound card and works perfect for my VDJ tks ACW for the recomendation....:)
Now I could play config BCD or even the audigy platinum
Dj quintana
geposted Tue 05 Dec 06 @ 7:31 pm
