Forum: Old versions
Topic: i'm pretty sure this is right....
ktilakPRO InfinityMember since 2006
I am going to buy a u46dj (for $212...is that a fair deal?) and want to use it and two cd decks for timecode, those same decks for normal cd play, and a hercules mk2 as a controller.
am i correct in that i will use y splitters to connect the cd decks to both the timecode and mixer? then i just selct phono/line on the mixer to decide between vdj and timecode or straight cd to mixer?
is there a better way to do this or was my forum searching actually successful!!
and of course im guessing the hercules will just sit there plugged in as a conroller only.
and that the soundcard setting will use the 2 timecode inputs and the u46dj soundcard?
ehhehhehhhh? im getting eeeexxxcited- gonna practice away and hope to use em in a club i have planned in january!
geposted Tue 05 Dec 06 @ 2:57 am
i think so, but make sure to conferm this, maybe people will have some input on how to connect this if i am wrong.
geposted Tue 05 Dec 06 @ 4:00 am
sbangsPRO InfinityMember since 2004
you can use phono from cd or vinyl to phono inputs
geposted Tue 05 Dec 06 @ 10:32 am
okay cool.
when using a y-splitter though, the line-level volume wont get reduced to the point where it will hurt the timecoded signal will it? my cd decks output at +6dvB .. im assuming thats plenty loud to be split and still send good signal through the u46dj and into vdj?
geposted Tue 05 Dec 06 @ 11:11 am
should be fine
geposted Tue 05 Dec 06 @ 11:16 am
