Forum: Old versions
Topic: Hercules MK2
I would first like to thank skyfxl for your help in the connections. I actually upgraded my sound card to 5.1 and bought some thumpin' speakers for it. It sounds GREAT!!!! I have a question. When I unplug the consloe and re-start my computer at another time, why does my computer say hardware not found. I need to then uninstall the program and re-install. Has this happened to anyone? If it did, how did you resolve the issue.
Many thanks,
Syberman
geposted Thu 07 Dec 06 @ 4:13 am
sbangsPRO InfinityMember since 2004
have u selected it as a control device
ul need to untick it when its not pluged in
geposted Thu 07 Dec 06 @ 11:01 am
I have found this happens to me also when I unplug the contoller and then when I plug it back in if I do not put it into the same USB port as when I first installed it. Same thing would happen it would say that it was new hardware that needed to be installed. Dont know if this is just my computer but try plugging back into original USB port u installed on.
geposted Thu 07 Dec 06 @ 4:39 pm
mest42085
doenst matter what usb port u plug into
but its a possible indicator u have faulty ports
geposted Thu 07 Dec 06 @ 4:41 pm
