Topic: Dac 2 problems
I am running a Dac 2 and I have downloaded the drivers and a mapper. The controller still does not seem to recognize any controls. The drivers seem to have installed but no luck. Can someone help?
geposted Fri 08 Dec 06 @ 12:44 am
you might get a quicker response by posting this in the Hardware forum
Hardware Technical Support
Please post here all questions or comments about the hardware used with Virtual DJ:
DJConsole package
XP10 controller
Timecoded Vinyl
...and all other supported hardware
geposted Fri 08 Dec 06 @ 2:24 am
pernPRO InfinityMember since 2004
If The DAC-2 CUE and PLAY LEDs are flashing when you start VDJ (Indicating BROWSE mode) the Controller/mapper is detected and working. Even if the "LED" in CONFIG - REMOTE CONTROL is red. Since the flashing of the DAC-2 LEDs are generated by the mapper.
It could be that if VDJ doesn't use internal mapper the LED is always red, even when the controller/mapper is detected and working.
geposted Fri 08 Dec 06 @ 9:30 am
sbangsPRO InfinityMember since 2004
does it show up correctly in device manager if not try a driver reinstall
geposted Fri 08 Dec 06 @ 1:23 pm
