Topic: Numark Axis 9
Are the numark axis 9's good cd players to use with virtual dj and use the timecode cd virtual dj .Generally I want to know if they are good scratch cdplayers because they are touch sensitive also. sorry also can I use a sound blaster live audigy to to setup also?
geposted Sat 09 Dec 06 @ 7:13 am
I would suggest using pioneers for scratching as they are the industry standard cd players.
You can use any sound card with virtual dj, but the sound blaster audigy does not have 2 ASIO inputs on it. You will need a better sound card for tccd
yes pionners are cool
try u465dj as a souncard
or maya 44 pci
