Topic: weird crossfader problem
hey guys...im having a problem with the internal crossfader when i use automix. The songs start to mix correctly, however, when the fader gets to the other side (new song), it jumps all the way back to the other side (old song), then jumps back again to the correct side (new song again). The result is a short stop in music. I dont know why its doin this and ive tried all the different crossfader options, with no luck. I recently updated to v4.1r2, but i dunno if the problem started before or after that update. Do you guys have any ideas as to what would be causing this?
geposted Sun 10 Dec 06 @ 10:38 pm
sbangsPRO InfinityMember since 2004
have u tried lowering your
proformance tab?
geposted Sun 10 Dec 06 @ 11:37 pm
Do you use any controller beside Keyboard and mouse?
geposted Mon 11 Dec 06 @ 10:06 pm
No, im just using the keyboard and mouse now...I think i fixed the problem by lowering my performance tab to 1024 (23ms)...which is weird cuz ive always left it at 512 (11ms) without this problem...not sure if updating to 4.1r2 has anything to do with it...but i think its fixed, so once again, thanks alot guys!
geposted Mon 11 Dec 06 @ 11:47 pm
your most welcome:)
geposted Mon 11 Dec 06 @ 11:48 pm
