tycoonentertainmentcanada - if you have a fix for the problem, what is the solution? There are alot of people that have had this problem and would be nice to pass the knowledge.
cstoll
cstoll
geposted Tue 19 Dec 06 @ 2:54 am
ok, Marcell. this issue killed me and first open virt dj- i tryed something that my new I.T guy suggested..Ctrl +alta +delete
then process's , left click set as priority then set the setting to real time.. then adjust the source in the program .. Try it out , and if ya still have issues then i will come the 364 kms and fix it when i got free time... Stretch
geposted Tue 19 Dec 06 @ 7:07 pm
thanks for the info there strech.
But it seems to have stopped. (I mentioned that 4 posts prior) ;)
And the Problem only happens on my HOME station that I use for practice and testing
The club/mobile rig is just fine.
I think the updating Directx cleared the bug but I'll run it while I clean up on thursday just to make sure.
Appreciate the offer but before you spend the money on gas, and be disapointed about it being the wrong comp in the club.
But we can always get drunk and go whoreing again!!!!
DJ Marcel
Purple Onion NightClub
DJ Marcel
geposted Tue 19 Dec 06 @ 10:45 pm
I have an update...
the problem with me doesn't occure anymore with any song if i hit the cue button first of e next track to be played. Very strange...auto cue is enabled tho !
Every song runs smooth in automix if I hit the cue button first. But I don't that's the idea.
It should run smoothly in automix.
Can someone who has the same problem test this and back my story up?
I do have disengaged beatlock on switch.
geposted Thu 21 Dec 06 @ 9:04 pm
winzclav wrote :
I have an update...
Have you made sure that your DirectX is up-to-date? And if not, update it to the lastest Oct 2006 and see if everything starts working fine.
geposted Fri 22 Dec 06 @ 5:20 am
geposted Fri 22 Dec 06 @ 9:42 pm
yup that was the problem !! I was convinced my drivers were up to date, but checked them just to be sure via the link you gave me !!!
first tests seem to be good !!! Thanks dude I owe you one.
Lol now i can test 5 days more... JIT...
geposted Fri 22 Dec 06 @ 10:39 pm
glad it worked!!
for you :)
for you :)
geposted Fri 22 Dec 06 @ 10:59 pm
Oooookaaaaayyyyyy.
Club rig this time.
I've finally upgraded up to v4.2r1 on my mobile/club rig.
I updated to lastest and greatest directx drivers available on microsoft update. and I still got the skipping on the songs.
settings.
autoupdate - off
charts - disabled
tooltip - disabled
msn - disabled
read id3 tags - disabled
security - ask
scrolling - normal
disc - 45rpm
pitch range - +/- 12%
Bpm engine - any music
Auto pitch match - disabled
auto gain - always 0
auto pitch reset - disabled
auto cue - disabled
auto headphones - disabled
disenguage beatlock - manual
force fade - enabled
fade length - 1sec
crossfader - scratch.
System
Asus k8v-mx - mainboard
Processor - sempron 3000+, 1.8 ghz
2X 512 sticks of RAM
Orig OS - Win 98.
upgraded to XP pro.
media player v10
Directx
Creative soundblaster 6.1 soundcard set in 3 channel external mixer mode.
no separate video card - don't use the video component as of yet.
SO.......
Any thoughts?
I was thinking of going to get a fresh copy of XP pro from the software store - it's only $150.00 now, and doing a format and re-install and update and such
DJ Marcel
Purple Onion Nightclub
Club rig this time.
settings.
autoupdate - off
charts - disabled
tooltip - disabled
msn - disabled
security - ask
scrolling - normal
disc - 45rpm
auto cue - disabled
fade length - 1sec
System
Orig OS - Win 98.
upgraded to XP pro.
media player v10
Directx
SO.......
Any thoughts?
DJ Marcel
geposted Fri 12 Jan 07 @ 10:15 pm
Marcel, what are the performance settings?
I know that on the rare occasion of my home machine I can recreate the skip when the SAFE MODE is checked and the Scratch Optimize for Quality w/Simple Algorithm is selected. Also, is you Latency in performance set to Auto.
cstoll
cstoll
geposted Sat 13 Jan 07 @ 12:52 am
yes it should be in auto - I'll double check
performance setting is at fastest
scratch is set for quaity + simple.
again I'll double check at work tonight
DJ Marcel
DJ Marcel
geposted Sat 13 Jan 07 @ 1:21 am
DJ Marcel
DJ Marcel
OK, if SAFE MODE is checked then uncheck it.
geposted Sat 13 Jan 07 @ 1:24 am
oooookay turns out it's the nut behind the wheel that needs adjustment.
updated directx to latest and greatest according to microsoft.
updated windows media player to v11 just to be on the safe side.
Sunday is a good testing night because for the first few hours we only have customers for the weekly pool tournemnt on the lounge half of the club.
Here is what happened
Automix still was skipping over songs in the playlist.
Automix still was randomly picking a spot to play in the track when force fade is one and set to 1 second.
Needless to say I was frustrated.
Then I noticed something....
When the songs are within the +/-% range of your pitch selection (+/- 8% for me) the automix functions perfectly, doesn't skip a song or do odd mix in points.
When they are out of range - then the problem starts.
so I can either increase my pitch range while playing pool on sundays
or make pre - programed playlists.
This is kinda frustrating for this situation - beginning of the night - first two or three hours are just background noise and mostly classic/new rock for the pool lounge, And you cannot beat mix rock music. a relay play function is what I use this as. Nothing more
I guess I could always use media player it has a limited crossfader function but this was a major selling point for me back in the VDJ3.4 days. That one worked just fine and dandy
Thoughts?
DJ Marcel
Thoughts?
DJ Marcel
geposted Mon 22 Jan 07 @ 11:12 am
Marcel - what are the Safe Mode and Overclock settings? And, the Scratch section?
geposted Tue 23 Jan 07 @ 1:02 pm
Safe mode and overclock are on
Scratch section is set to simple.
Not too sure about that scratch section there. I Don't scratch so I've always had it set to simple.
geposted Tue 23 Jan 07 @ 5:39 pm
Uncheck the Safe Mode and Overclock. This is a your desktop system at the club right? Shouldn't need the Safe Mode OR Overclock.
geposted Wed 24 Jan 07 @ 4:27 am
Acutally both systems are on a desktop - just the one at the club is a small form compy.
I'll try that and test.
Might make some pre-programmed lists as well
I'm going to be doing a swap out here in a little bit
Gonna change the sempron system for a pentium d dual core
and add a video card.
geposted Wed 24 Jan 07 @ 4:48 am
I am familiar with the problem. To me it seems that even if auto-cue is off (which is always disabled when you use force fade) VDJ still jumps to the first cue and mixes out on the last cue. Sometimes the first cue (= first beat of the song when you don't cue manually) is placed in the middle of the song.
Could it be possible that auto-cue can't be disabled with automix, despite force fade? (some sort of bug?)
geposted Thu 25 Jan 07 @ 1:13 am
Update time.
I unchecked overclock and safe mode
Performance tab is set at fastest
Set pitch range to +/- 34%
force fade enabled and set @ 2 seconds
Set up a playlist for a hour and a half before going to work last night and let it play out in my apartment. Worked like a charm
problem seems to be solved again.
DJ Marcel
DJ Marcel
geposted Fri 26 Jan 07 @ 10:19 pm
your welcome...
geposted Sat 27 Jan 07 @ 12:40 am
