Forum: Old versions
Topic: regular vinyl not working
Hi guys i am almost setup here..... got rid of the humming/buzzing sound by muting the Monitor buttons on the u46dj.
Now i cant get my regular vinyl to play through VDJ. i set numbers 1 and 2 buttons to activate deck under keyboard controls. i put on the regular vinyl Hit the 1 Key and..... Silence?????
i use the RIP VINYL feature and i have to use the USB 3- USB 4 under inputs.... but i hear the regular vinyl fine!!!
WTF is going on???
geposted Tue 12 Dec 06 @ 5:21 am
could you post your sound config as a screenshot
ok ill try to get a screen shot tonight.
again..... i am no longer using the Mk2. THIS is on the trial version.
sorry could not get a screenshot.. i dont have a picture editor on my computer.
BUt i unmuted the monitor channels on the u46dj and now can hear regular vinyl, its just that the humming noise is now back!!
also it seems changing back and forth from regular vinyl to TCV makes the program crash (well not the whole program ) but the hotkey to switch back and forth
to take a screenshot press Shift and Printscreen on ur keyboard then go to paint
and press paste
then upload the image onto tinypic.com and they will provide a link
