Topic: Num of Decks
What's the max number of decks virtual dj uses?If it uses more than 2,how do you get 3 or more?
geposted Tue 12 Dec 06 @ 5:26 am
2 timecodes currently supported per instance
its probaly possible to support more in multiinstance mode
If you use multi instance, you will need a second soundcard to make timecode work
cool there u go :)
