Topic: PCI ESI MAYA 44
rowl3yPRO InfinityMember since 2006
hi guys
i phoned ESI today and asked them about the ESI MAYA 44 PCI
They said this will be no good for VDJ as the record deck's have a low output and i need like a amplfi the sound for it to work
They said the U46Dj has a bult in litte amp for turntable
byt there has sound out and stoped making them as a new one coming out next year..
Is there anythink else i can use Please i need major help
i was just about to buy the ESI MAYA 44
is it turn has anyone got 1 ??
thanks
geposted Tue 12 Dec 06 @ 5:25 pm
Its true what they say, the maya needs software amp, while the u46dj has hardware amp, of the vinyl signal. So the U46dj card should work better...
It seems ESI is making a new model that will replace the u46dj, so I'd wait a bit if I where you, or get the u46dj from a store that has it in stock :)
BTW, Numark will release a boxed version of VDJ with soundcard, vinyls and all, after xmas.. So that might also be a good option ;) its called Numark Virtual Vinyl
geposted Tue 12 Dec 06 @ 7:05 pm
DAM DAM DAM DAM
i just paided for the PCI 44 is there anythin else i can use this will to get it to work
thanks
man i all was mess up
geposted Tue 12 Dec 06 @ 7:18 pm
Dont worry ;) I was not saying it works bad.
The maya44 pci might work great, as VDJ have software preamp...
Remember that maya44 usb is a card that is loved by many VDJ users ;)
So I bet the card will work good for you :)
And PCI should give you super low latency
geposted Tue 12 Dec 06 @ 7:19 pm
wow first person i know that made me smile
so the VDJ software is pre amped
i have yeh wait to have a look as im gonna ge thr trial version to setup
i hope the it does work
i have order my timecoded vinyl's how long did ur's take
i have contect them asking how long they ent replyed in 2 day;s :(
geposted Tue 12 Dec 06 @ 7:34 pm
VDJ has software amp yes;)
Needed for almost all cards in use by VDJ users:) except a few , like u46dj
And timecode should take a week at the most I think ;) Sent from France to UK
Glad u are smiling again;)hehe
geposted Tue 12 Dec 06 @ 7:42 pm
one again thanks very mucvh wol;l report my finding's
geposted Tue 12 Dec 06 @ 7:47 pm
I have been using the PCI version of the Maya 44 card for years. Before when it was Audiotrack's hardware. It works great with the TCV's. I have it set real low on the latency and it I haven't had any big issues thus far.
geposted Wed 13 Dec 06 @ 2:08 am
sweet mate thanks very much mine shuld come tomorrow
geposted Wed 13 Dec 06 @ 7:09 am
