Hey guys i'm right now back on the cruise ships, and i bought my bcd2000 with me,when i got here i found out that they have 2 HDX and a DAC3 with a gigaport sound card, now does anybody have any idea what will be the best to hook up with VDJ,Thanks a lot,VDJ Bruno.
geposted Tue 12 Dec 06 @ 9:02 pm
Do yourself a favor and leave the bcd in your cabin. They have much better equipment.
geposted Tue 12 Dec 06 @ 9:11 pm
i now, but how i connect the HDX as a controler? Can i connect with VDJ?
geposted Tue 12 Dec 06 @ 9:15 pm
Try the DAC-3 with my custom mapper:
http://www.virtualdj.com/addons/download.html?addon_id=2401
The HDX will probably only work with timecode CD.
geposted Tue 12 Dec 06 @ 9:23 pm
The DAC 3 with his mapper. It is so sweet.
geposted Tue 12 Dec 06 @ 10:05 pm
I must agree use the dac-3
geposted Wed 13 Dec 06 @ 12:16 am
do you guys have any idea what the HDX is capable of.
it's amazing, the response of the turntable is realy good.
it's verry hard to make a decision,but in the end i do as well think the the Dac-3 works great with VDJ.
geposted Thu 14 Dec 06 @ 6:50 pm
well you can use both if you want to. The HDX will basically offer simple control as well as ample hard drive space. The device itself is extremely powerful but if you use it with VDJ, most of its functions will be found on the DAC. Dont use the BCD though.
If you can get them both hooked up in asio, you got a perfect compliment to the DAC-3 :D
geposted Thu 14 Dec 06 @ 7:47 pm
