CAN ANYONE PLEASE SEND ME INSTRUCTIONS ON HOW TO USE THIS PLUGIN ? IT'S ACTIVATED AND APPARENTLY WORKING, BUT! I DONT KNOW HOW TO USE IT ,AS FAR AS HOW TO CHANGE AND CONFIGURE THE BUTTONS. I'VE TRIED A COUPLE WAYS AND IT DOESNT TAKE EFFECT.
"DJ DEEPREZZURE"
"DJ DEEPREZZURE"
geposted Thu 21 Dec 06 @ 12:19 am
are you sure you have the latest revision?
geposted Thu 21 Dec 06 @ 12:28 am
![](http://img81.imageshack.us/img81/5507/mapperokte9.jpg)
geposted Thu 21 Dec 06 @ 4:03 pm
YES, I DO HAVE THE 4.1.1 VERSION . IM JUST NOT UNDERSTANDING HOW TO SET IT UP / USE IT.
WHERE AND HOW DO I INSERT AND CHANGE THE DIFFERENT CHOICES. YOU KNOW, WHAT DOES VALUE AND NO SIGN MEAN . I DONT UNDERSTAND ID IS ALL , THANKS!
geposted Fri 22 Dec 06 @ 1:18 am
the values work by giving istructions via midi
+ means make a setting increase
- means make a setting decrease
no sign means a direct action
click on the button you would like to change on the mapper
for example say i want to mapp all 3 buttons on mk2 to activate fx
id choose value "activate fx"
and no sign 0
hope that helps
and no sign 0
hope that helps
geposted Fri 22 Dec 06 @ 3:21 am
YES THANKS, YOUR INFO HELPED ME TO UNDERSTAND A LITTLE BETTER. BUT, FOR EXAMPLE I WOULD LIKE TO SET IT UP WHERE MY PARAMETER BUTTONS GO ON MY PITCH BEND BUTTONS. I CAN'T FIGURE THAT OUT. I DON''T EVEN SEE AN OPTION FOR PARAMETERS IN THE LIST. WHATEVER I DECIDE TO COOSE FROM LIST GOES INTO THE NOTHING WINDOW ,CORRECT? THEN I CLICK ON THE NO SIGN ,CORRECT? THEN I CHOOSE APPLY ,CORRECT? I REALLY APPRECIATE IT ,IM NOT EXACTLY A COMPUTER WIZ!
geposted Fri 22 Dec 06 @ 6:00 pm
that should be fine , :)
geposted Fri 22 Dec 06 @ 6:12 pm
