Topic: Recommended Ripper?
OGBJHome userMember since 2006
I was just wondering if you all had a CD ripper that you could recommend.
I was using the ripper in another dj program, but that program was causing my system way too many errors. I started using AudioGrabber which was great, but I have a lot of remix CDs that I have to manually enter to rip. The problem is that on these compilation mix cds, the artist isn't showing up in VDJ when I rip using AudioGrabber.
Is there a Ripper that you all could recommend that a) can access the online database for info (for store bought CDs) and that will transfer the artist and song name into VDJ for burned compilation CDs?
geposted Sat 23 Dec 06 @ 5:52 pm
I use audiograbber myself.......you used to be able to make that work even with some cheap consumer music software......i'm guessing that the culprit is DRM........anyway i amsorry to say i know of no solution for compilation discs.......
geposted Sat 23 Dec 06 @ 7:00 pm
you can type in the info yourself.....it can be tedious no doubt.
geposted Sat 23 Dec 06 @ 7:03 pm
a.k.a. the problem with yer great ol mixtapes........
geposted Sat 23 Dec 06 @ 7:48 pm
winamp. pro version. but we're just kookey that way.
geposted Sat 23 Dec 06 @ 7:59 pm
geposted Sun 24 Dec 06 @ 1:09 am
CDex by far the best for me
geposted Sun 24 Dec 06 @ 3:21 pm
fmooijPRO InfinityMember since 2004
geposted Sun 24 Dec 06 @ 4:10 pm
abnormPRO InfinityMember since 2003
Been using CD-DA extractor for years. Awesome software, and uses the best encoders/decoders.
geposted Sun 24 Dec 06 @ 8:50 pm
Thanks everyone for the responses. We can consider this problem officially solved.
geposted Sun 24 Dec 06 @ 9:12 pm
sbangsPRO InfinityMember since 2004
horray
geposted Sun 24 Dec 06 @ 9:29 pm
