Forum: Old versions
Topic: % MK1 Signal To Mixing Board %
Last night for the first time I used my KM1 with the sound card option @ my gig… The MK1signal sent to the mixing board wasn’t acceptable low.
In order to get any sound in the head phones (cue) I needed to turn the gain to max on the mixer and that was still unacceptable and I was still not in the red.
I tried upping the gain on VDJ and that didn’t help much and I was teetering on distortion.
The MK1 Output Channels I first tried (Master 1&2) (Headphones 3&4), The (Master 1&2) (Headphones 3&4) no change.
I finally gave up and used the computer onboard sound card.
It worked perfect as usual.
I want to use the MK1 sound card so I can utilize the cross fader and headphones, (left ch/right ch) on the MK1 and run the master through my main mixing board. Channel 1 for master and channel 2 for headphones..
Thanks John
geposted Sun 24 Dec 06 @ 9:41 pm
sbangsPRO InfinityMember since 2004
have you boosted the output channels on the mk1 control pannel?
you can find it as an icon on ur task bar :)
happy xmas
geposted Sun 24 Dec 06 @ 9:44 pm
SKYFXL,,, Your are Truly a Genoese.
I hed to gointo the Herciles Folder to find that dam allian.
I ask yesterday about controlling the mapping on the MK1..
The Mapper doesn’t show under FX+External Devices as you illustrated so elegantly.. I open the djcmapper in VDJ/Plugins/Control Divices.. Is this right?
geposted Sun 24 Dec 06 @ 10:10 pm
yes thats right :) good luck :)
geposted Sun 24 Dec 06 @ 10:13 pm
Thank you but I still don't see the mapper under FX+EXD..
geposted Sun 24 Dec 06 @ 10:15 pm
is it saved any where else ?
if so just copy it into the external devices folder
geposted Sun 24 Dec 06 @ 10:17 pm
I searched the C drive for djcmapper delited them and reinstalled it in the external devices folder.
I rebooted, opened VDJ, selected Effects tab, selected External Devices. All that’s there is a gray box.
geposted Sun 24 Dec 06 @ 10:34 pm
are you sure you have the latest one?
geposted Sun 24 Dec 06 @ 10:39 pm
You are freakin’ great
Thank you for your time an the opportunity to take advantage of you ultimate wisdom.
Have a great day.
geposted Sun 24 Dec 06 @ 10:54 pm
:) thanks lol
have a good day 2 :)!
geposted Sun 24 Dec 06 @ 10:56 pm
