Forum: Old versions
Topic: BCD 2000 +VDJ+ LAPTOP: need clarification and help guys
Hi guys I
i need help and advice regarding VDJ and BCD 2000 and your experience!
* I have a laptop and external soundcard ( soundblaster audigy) that plugs in via usb.
* i want to buy BCD 2000 and VDJ but want to know from you man if this set up will work.
* i know that people say that if you use BCD2000 as CONTROLLER it works better....
* so does that mean i can use the soundcard on my laptop (realtek) the external usb audigy soundblaster and bcd2000 as controller?
I have read read posts in this forum and they are alwayse insightful.
Any help regrding mappers that you recommend or anything else that you think i should do would be appreciated.
Basically i wanna have a set up that i can take around and play my music off external hardrive with bcd 2000 and my external soundcard.
Do you think i should also buy a powered usb hub to stop any crackles?
Finally what version of VDJ works best with BCD 2000....
thanking you in advance gents
thanks to maxmora fo your reply
Arrabistadj
geposted Tue 26 Dec 06 @ 9:32 am
sbangsPRO InfinityMember since 2004
heya
yes you can aslo use those cards :)
and use the bcd
a powered hub would help improve power
and quality
it works best with 4.2r1 pro
http://www.virtualdj.com/purchase/
geposted Tue 26 Dec 06 @ 1:07 pm
