if I bought the pro version of Virtual Vynil and bought a numark dm950usb would i be able to make good use of TCV
geposted Thu 28 Dec 06 @ 5:55 pm
virtual vinyl is a soundcard in its self. bundled with numark cue :)
as details are yet to be published:)
id imagine that it would alow you to use an external mixer with it
you can use any midi controler with it for sure :)
geposted Thu 28 Dec 06 @ 6:58 pm
The dm950usb works already with VDJ, and will also work with Numark VV ;)
geposted Thu 28 Dec 06 @ 7:41 pm
there u have it ;
geposted Thu 28 Dec 06 @ 8:25 pm
sorry I got my names crossed what i ment was will virtual dj pro work with that mixer while using TCV. if so will i be able to use two TCV at same time and would I still need another sound card. Sorry
geposted Thu 28 Dec 06 @ 8:34 pm
yes i belive you can
choose 2 cards as sound setup option
and select this card 2 times :)
will be like dd950 1 and 2 :)
geposted Thu 28 Dec 06 @ 8:37 pm
Think you might need a new soundcard if you want to use timecode.
As far as I know, that mixer does not have line-ins that will route sound from timecode to the PC.
It only has USB, that will allow you to play directly from VDJ to the mixer, and record from the mixer at the PC, but doesnt have the function you need, that is line-in to usb, so that sound can travel from turntables with timecode to the pc.
As far as I know..
geposted Thu 28 Dec 06 @ 9:00 pm
it has two usb cables to act like two soundcards i read :)
geposted Thu 28 Dec 06 @ 9:13 pm
no clear answer i see.
geposted Thu 28 Dec 06 @ 10:54 pm
"Two USB ports are included so you can take advantage of the multiple sound card feature found in most DJ mixing software. "
should be fine to your wants :)
if you choose two cards
i belive
geposted Thu 28 Dec 06 @ 11:07 pm
I'm sorry if I wasn't clear...
It DOES NOT work with timecode inputs, no..
In order to use TCV or TCCD you need a 2 in- 2 out soundcard, like mk2, maya 44, u46dj, etc...
Your mixer has is 2 soundcards, one for each channel, and thats 2 outputs... but you still need 2 in, one for each timecode... And your mixer does NOT have this feature.
Sorry.
geposted Thu 28 Dec 06 @ 11:14 pm
I own this mixer, It does have 2 inputs, but I dont think they work with TCV. You can set them to record the Master output into another program. It is a great mixer. Sound is nice.
geposted Tue 09 Oct 07 @ 5:14 am
