What is differant?
geposted Thu 28 Dec 06 @ 8:45 pm
geposted Thu 28 Dec 06 @ 8:55 pm
I updated to 4.2 now VDJ does not recognize dac3??? It worked before...any ideas....
Thanks
Mark Allen
Thanks
Mark Allen
geposted Thu 28 Dec 06 @ 9:36 pm
what happens red icon?
geposted Thu 28 Dec 06 @ 9:44 pm
I guess that I don't understand all of these new features and such mean (sorry if they are obvious):
new HD mode for Timecode CDs ???
absolute mode fixed ???
adjustable auto-pitch sensitivity ???
new features:
virtualfolders automatically remove duplicates ???>>>>I'm not familiar with virtual folders
new query for plugins (maineffect*, mainsample*) ???
new action: timecode_mode ???
Thanks in advance!!!
new features:
geposted Thu 28 Dec 06 @ 10:35 pm
hi defination i guess
had a small bug now fixed
you can adjust how sensitive the program is to changes in pitch on ur pc
new features:
if you add the same file twice its removed;)
main effect and samples , for more info look on keaboard shorcuts its all explained there :)
new shortcuts]
timecode mode chooses which mode ie smart ect
new features:
new shortcuts]
gluck;)
geposted Thu 28 Dec 06 @ 10:54 pm
Thanks
Mark Allen
Thanks
Mark Allen
Might be that you did not have the DLL drivers in the
c:\Program Files\VirtualDJ\Plugins\ControlDevice folder.
You should get the new DAC-3 mapper from the website and install the DLL in that folder.
I have was running 4.1R2 and no issues, I just upgraded also and do not see any issues so far.
geposted Fri 29 Dec 06 @ 8:11 am
The DAC-3 now has its own separate tick box in the Remote Control tab of VDJ's config.
Make sure you tick the DAC-3 and untick DMC/DAC-2.
geposted Fri 29 Dec 06 @ 3:36 pm
Yes I had the same problem, I was crapping myself as i'm on tonight, I IM'd jp and he saved saved the day for me. Thanks again Jonathan
geposted Fri 29 Dec 06 @ 6:16 pm
