Topic: VDJ Video
myselfPRO InfinityMember since 2004
Hi
In order to get video from VDJ onto a tv or projector do I a special graphics card?
I am now looking to utilise the video side of VDJ into my gigs and would like to know where to start.
Many thanks in advance.
Craig
geposted Sat 30 Dec 06 @ 3:37 pm
You will need a graphics card with TV out on it for this. Most of the latest cards have this, although I would recommend a high spec card as video takes processing power.
As long as the projector has an input for S-Video, you should be able to hook this up in much the same way.
Mykel
geposted Sat 30 Dec 06 @ 4:37 pm
sbangsPRO InfinityMember since 2004
on a laptop or pc?
geposted Sat 30 Dec 06 @ 5:13 pm
I use a shuttle small form factor pc. Unfortunatley it only has one PCI slot and that is taken up by the soundcard! I will have to look at getting an external graphics card...if there is such a thing.
2.5Gig AMD processor
2x120gig hd
1gig ram
soundblaster card
Thanks
edit-
I have an AGP slot free and can have read that I can put a graphics card in here! Great! Which card would you recommend?
geposted Sat 30 Dec 06 @ 5:20 pm
geposted Sat 30 Dec 06 @ 5:38 pm
good job sky....
geposted Sat 30 Dec 06 @ 10:06 pm
ta :)
geposted Sun 31 Dec 06 @ 12:49 am
Also, the size matters. Some of the new high end cards are longer. I am building a new SFF, and may have to mod my case. Just got this case, and have not yet picked the card. After reading the reviews of the case, I can only put in a 8" card. Some of the cards are 9", so I will have to make an adjustment, if I use one of these. I would have been pissed, if I did not know this in advance. Great job skyfxl.
geposted Sun 31 Dec 06 @ 1:31 am
yes its true size does matter;) lol
geposted Sun 31 Dec 06 @ 1:40 am
Thanks skyfxl for pointing me in the direction of your article. Very interesting! I'll go now and choose one which matches my case spec and budget. At least I am armed with some good info.
Thanks again guys!
Craig
geposted Sun 31 Dec 06 @ 1:12 pm
good luck :-)
geposted Sun 31 Dec 06 @ 1:15 pm
