Topic: New Mix For Download
First mix i have posted for a while, its only a 4 track mix but still a mix, bad part is the last mix went pretty bad (pretty being ironic)
Download Here
Leave your comments
geposted Fri 06 Aug 04 @ 7:31 pm
erxonPRO InfinityMember since 2003
Hum, no offence, but beats are way off 4 my ears ;) And you should lower the bass levels on mix-in track. Otherwise ok. Maybe use some samples that are from similar tracks. That "hands up in the air" was a bit too loud, so it doesn't really fit in the mix. Just my little opinion ;) Have fun mixing
geposted Fri 06 Aug 04 @ 8:51 pm
beats are way off? on all mixes?
and the "hands up in the air" isnt a sample its in the actual song
geposted Sat 07 Aug 04 @ 9:29 am
"Way off", I ment that the bass level of two beats crossing over each other variates too much, and it doesn't sound well (like the songs weren't beat matched, with a slight offset). As I said, try lowering bass levels of mix-in song, and than switch.
1 more thing, did you use time stretching? That probably makes the beat sound strange at some points.
Actual song... hm, OK ;) still I'm not sure if it fits well with the melody of the other track :)
Since I was so critial, I'll upload one of my mixes (still have to record it, have to find a cable lol ;), so you'll be able to criticize mine 2 ;) enjoy!
geposted Sat 07 Aug 04 @ 9:44 am
lol thanks no worries i appreciate your comments!
geposted Sat 07 Aug 04 @ 9:59 am
I attempted to download your mix. Unfortunately, it was going to take one hour and 15 minutes. I’ll try again when I get a faster internet connection—I’m thinking about getting DSL.
geposted Mon 09 Aug 04 @ 8:31 am
