Topic: SAMPLE DOWNLOADS...
So I have downloaded some samples on this website to the Sample Folder in the Home Edition Program. When I am in the program and try to load a sample it never works...and I am stuck with a stupid Siren.
What am I doing wrong?
Thank you
geposted Sun 31 Dec 06 @ 3:52 am
Are the samples marked "for pro users only", or something like that? Then we can work from there.
No, I made sure to download the Home Edition versions.
I don't have the home edition so, I can not give you a step by step solution. In the pro version, you have to load the sample into the module. Is there a tab you can rt click, to bring up a menu, to load the sample to that spot? I am sure someone will be here to help you.
ok
download the sample you want then place it
in C:/programfiles/virtualdj/samples
in the sampler then press the arow symbol to load now choose that sample and press load :)
for more info on what is available for home users
read here
comparison
